Novice » Procesorji » Zaradi hude ranljivosti bodo Intelovi procesorji do 50 odstotkov počasnejši
![](https://static.slo-tech.com/stili/avatar_gray.gif)
Isotropic ::
krneki0001 je izjavil:
Vau, kakšna razlika. Pred in po updejtu (pred je temno oranžna, po je svetlo oranžna):
če imaš kakšen 3rd party antivirus, verjetno sploh še ne dela popravek, kljub temu, da je nameščen.
![](https://static.slo-tech.com/stili/bel_non_grata.png)
Sej vem da je težko v številkah govoriti .... With Windows 10 on newer silicon (2016-era PCs with Skylake, Kabylake or newer CPU), benchmarks show single-digit slowdowns, but we don't expect most users to notice a change because these percentages are reflected in milliseconds. With Windows 10 on older silicon (2015-era PCs with Haswell or older CPU), some benchmarks show more significant slowdowns, and we expect that some users will notice a decrease in system performance. With Windows 8 and Windows 7 on older silicon (2015-era PCs with Haswell or older CPU), we expect most users to notice a decrease in system performance. Windows Server on any silicon, especially in any IO-intensive application, shows a more significant performance impact when you enable the mitigations to isolate untrusted code within a Windows Server instance. This is why you want to be careful to evaluate the risk of untrusted code for each Windows Server instance, and balance the security versus performance tradeoff for your environment.
Sicer pa testov za posamezne aplikacije ni, nekako vse se skriva.
France Rejects Genocide Accusations Against Israel in Gaza,
To accuse the Jewish state of genocide is to cross a moral threshold
krneki0001 ::
Nimama antivirusnega programa in točno vem kdaj se mi kaj poinštalira v mojem računalniku.
Predator X ::
Okey.
+ Windows update
+ Bios Update
Poleg tega stem rešiš samo 1 en problem. Za ostle probleme rabiš menjat hardware @ CPU!
+ Windows update
+ Bios Update
Predator X ::
Nevem zakaj se obremenjujete, ta problem je znan že dolgo časa. Za avg userja je čist nepomemben.
Zobje rabijo kost. Za gristi. ;)
- spremenil: MrStein ()
Predator X je izjavil:
Za avarage jo, ki FB na maximalno predzadnji genearaciji procesorja, ne bo razlike. To je napisal MS. Na Gen5 cpu-ju in še huje če nisi na Wind 10 (marketning), je jasno napisano da je opazno za avarege joe. Itak redko pokuri vse procesor core, in če je en na 100%, se skoraj ne opazi...
30% na Oracle bazi pomeni, investicija v novo škatlo. Do tu imaš srečo. Če pa si na zadnji verziji škatle, pomeni nove oraclove lience, to je zelooooooo drago.
Tole je od AWS : https://www.theregister.co.uk/2018/01/0...
Tole je sicer en ESX test :
Imam eno staro škatlo, ki še nima apdejtov.
Katere benchmarke priporočate za prej/pozneje?
Pa pozor, da ne boste pozneje: Ja, ampak v tem-pa-tem benču pa bi bila večja razlika!
![;)](https://static.slo-tech.com/smeski/icon_wink.gif)
konspirator ::
Je kdo že izračunal, za koliko je/bo v data centrih narasla poraba elektrike ?
Mr.B
Še par patchev in bo hitrost kot na 10 let stari kišti s klasičnim hdd.
Mr.B
- spremenilo: konspirator ()
Samo oracle bazo maš itak izolirano.
Seveda, takoj ko mi ti podpišeš, da boš odgovorajal z obema ledvicama in jetri, pa da bo šlo skozi verifikacijo, pa mi bodo dodali nazaj certifikat, etc...
Po drugi strani moraš pa VM petch namestiti tako na host kot tudi na VM. Sicer pa amazon pravi, da zgubi zaradi tega patcha samo na intlu skoraj en slovenski letni proračun. Ni malo.
Ampaj domači janezek, pa no sej vidimo. majnerji na nv že jamrajo, če si na nv kartici...
krneki0001 ::
Zanimivo. HP bo izdal tudi za pre 2013 proce in mašine popravke. Vsaj za Z420 imajo napisano, da bodo izdali popravek 15.1.2018. Pa je to mašina iz leta 2011 in proci so od takrat (E5-26xx V1)
https://support.hp.com/us-en/document/c...
- spremenilo: krneki0001 ()
Edino prav. INTEL bi moral urediti in kriti stroske tega za vse CPU in maticne plosce zadnjih 10 let. Najmanj, kar lahko po tako hudem zajebu naredi.
In ne, ne vidim nobenega razloga, da bi nekdo menjla sistem, ce mu zadostuje, samo, ker je INTEL zajebu. A naj ga se nagradimo s povecanjem prodaje?
Pa še na on board SATA 3G priklopu (Intel H61 chipset - Medion P5350D)
5 let in 11 TB pozneje (plus patch za Meltdown):
Praktično nič razlik.
PS: Get-SpeculationControlSettings pravi, da za Spectre nimam HW podpore. Torej samo Meltdown patch je aktiven.
Na SSD se mi torej nič ne pozna.
Window 8.1 64bit
Intel Core i5-2320
What BIOS update? To ni Apple (*triggered*)
krneki0001 ::
Na 8 jedrniku nisem nič opazil, na taveliki (2x 14 jeder) mašini pa je malo počasneje v virtualkah (mašina s popravki in virtualke s popravki), ni pa toliko, da bi se sekiral. Bom dal še malo rama v mašino, pa bo vsaka virtualka dobila še par giga rama in bo pohitrilo zadeve.
» | Preizkus popravkov za Meltdown in Spectre: Intel ob 10 odstotkovOddelek: Novice / Procesorji | 8769 (6389) | D3m |
» | Nova ranljivost v Intelovih procesorjihOddelek: Novice / Varnost | 7866 (5564) | bbf |
» | Ranljivost v vseh operacijskih sistemih zaradi napačnega branja dokumentacije procesoOddelek: Novice / Varnost | 4904 (3089) | GizmoX |
» | Intel le popravil procesorje Skylake, Kaby Lake in Coffee LakeOddelek: Novice / Znanost in tehnologija | 15515 (12671) | tikitoki |
» | Kaj vemo o napadih Spectre in Meltdown na procesorje (strani: 1 2 )Oddelek: Novice / Varnost | 34274 (28769) | D3m |
