Forum » Mobilne tehnologije » OnePlus 5
OnePlus 5
![](https://static.slo-tech.com/stili/avatar_gray.gif)
dunda ::
mene pa nekaj zanima ali se pri naročilu direktno iz trgovine oneplus plača carina --torej 499€ + dajatve ?
če mi lahko kdo pove.
Plačaš samo ceno na njihovi (OnePlusovi!) spletni strani. Pošiljajo iz Evrope in očitno s carino že prej uredijo.
https://www.kacnje.eu
Jerry000 ::
OP telefoni niso najbolj znani po kvalitetnih fotoaparatih kajne? So bolj povprečni (ne v rangu samsunga, iPhone itd).
Tomson ::
Do modela OP5 so bile fotografije kvečjemu povprečne, pri OP5 modelu pa se je situacija precej izboljšala, z dobro dvojno kamero, ne zajema še slik v rangu flagship Samsung S8/iPhoneX/LG V30/Pixel2 telefonov, so pa fotografije zelo, zelo dobre in že precej blizu najboljšim modelom na trgu...
CNET
In general, the OnePlus 5 has a superb camera (and its 16-megapixel front-facing shooter takes sharp selfies as well), if not one of the best camera phones around. When it comes to regular day-to-day shooting, though, personal preference comes into play -- especially when all premium phones carry first-rate cameras.
TRUSTEDREVIEWS
The high megapixel count captures very detailed shots that are full of colour and vibrancy, while the wide aperture on the main lens allows for more light to hit the sensor when it's dark. Both low-light and daytime pictures look really good, though it can struggle with glare when it's really sunny. The auto-HDR mode does help here, levelling out the exposure and contrast without making it too obvious. The lack of optical image stabilisation also becomes apparent when really pushing the telephoto lens, as it can become hard to hold steady and avoid a blurry and noisy shot. The EIS (electronic image stabilisation) does a good job most of the time, but it sometimes lacks consistency.
ANDROIDAUTHORITY:
Photos taken with the OnePlus 5 are well detailed, sharp without looking over sharpened, and color reproduction is more on the natural side and not overly saturated. The secondary telephoto lens is great for getting those closer up shots without losing as much detail as you normally would from purely digital zoom. It's perfect for getting closer on anything you want, but I found it to be especially great for macro shots. It is important to mention that it does produce slightly different colors from the main lens and is a little more inconsistent with exposure.
Low-light performance will depend on which camera you decide to use, with the second sensor being the weaker of the two due to a smaller pixel size, smaller aperture, and no stabilization. Photos from the telephoto lens are much more washed out, noisy, and full of lens flares and overblown highlights. White balance is the biggest issue of them all, though. The main sensor will give you much better results especially in terms of detail and color accuracy.
EXPERTREVIEWS
The rear snapper, manufactured in collaboration with DxO Labs, incorporates one 16-megapixel, f/1.7 main camera and another, 20-megapixel f/2.6 telephoto camera right beside it. Both work hand in hand to produce fantastic-quality snaps and some of the best I've seen on a device at this price point.
That 16-megapixel camera is your main snapper, but just like with the iPhone 7 Plus, the 20-megapixel camera works as a 2X zoom for getting closer to objects in the distance. It'll also help with producing an iPhone-like Bokeh effect, blurring the background without sacrificing subject quality.
CNET
TRUSTEDREVIEWS
ANDROIDAUTHORITY:
EXPERTREVIEWS
RoccoC ::
Znanec je nabavil 5T, prejšnji telefon (ki ga še vedno ima) je bil pa Nexus 6p Pravi, da je 5t proti 6p super - mnogo hitrejši, dosti lepše sede v roko, ekran je prav tako dober, edino nad kamero je pa razočaran. Pravi da če direktno primerja slike in postavi da je 6p 10/10 je 5t zgolj 7/10....
Sparkxl ::
Nekje se pač mora poznati da je telefon kar precej cenejši od taglavnih playerjev.
Jaz imam tudi Nexus 6p, v nedeljo sem naročil 5T. Mislim da bo dostojen naslednik, če so fotke vsaj približno take kot na 6p bo za mene ok
SumTingWong ::
Oreo update coming. Face recognition + Europe network fix
Glede na leake pa bo zelo všečen OnePlus 6. Če ne bo šla cena za 100EUR gor (napram 5T), se bom definitvno ogrel zanj.
![8-)](https://static.slo-tech.com/smeski/icon_cool.gif)
Karen ::
Oreo imam že gor (sem se zafrkaval cel vikend), ker sem dal OTA na odklenjenega 5T s TWRP (zadnjo verzijo), ki ga povozi OTA z default recoveryjem in mi potem zadnja verzija TWRP-a, ki sem jo spet dal nazaj, ni znala "dešifrirat" sistema, ki ga po defaultu pač šifrira Oreo, pa tudi prejšnji OTA update 7.1.1. Skratka sem prebral pol neta... Končno našel eno univerzalno verzijo TWRP-a ki je pokazala pattern za odklent in potem "videla" vsebino.
Face recognition je delal že na 7.1.1. čisto solidno. Lahko potrdim, da je telefon zakon (prej imel Oneplus 1 dolgo), pa vmes nekaj kitajskih "polizdelkov", pa lahko potrdim, da je 5T spet nekaj kar dela brezhibno vse kot mora.
Za fotoaparat nimam primerjave (recimo proti Xiaomi RN4 je kot noč in dan; boljše tudi od Samsung Galaxy S7edge). Fotk naredil le par, pa ni nobena zrnata, niti v slabših svetlobnih pogojih. Nisem pa stručko za fotke, ampak meni je tole kar pofotka amerika za moje potrebe... če bi imel kaj boljšega za primerjavo bi mogoče vedel. Lahko le potrdim da vse dela kot mora, LTE laufa kot nor, skratka računam na dolgo "prijateljevanje".
Guzzy ::
Pa kamera? Ali se koncerte da normalno snemat, tj. ne hrešči ko predvajaš (ne zjebejo ga basi in previsok zvok). Za primerjavo iPhone-i super snemajo koncerte in ujamejo vse zvoke, vsak koliko sem do zdaj videl.
![](https://static.slo-tech.com/stili/bel_rudis.png)
starboi ::
Kamera je povprečna v primerjavi z ostalimi flagshipi, sploh pa v slabih pogojih. Tako da ti odsvetujem nakup, če nameravaš snemati kakšne koncerte ali kaj podobnega .
Guzzy ::
Hvala za odgovor, sam ne nameravam kupit, me je samo zanimalo, ker mam OP2 in je snemanje zvoka pretty shit.
SumTingWong ::
Ne vem kakšen uporabnik sem potem jaz, ampak mene OP5 še ni razočaral. Kamera (foto + video) na S7 je bila meni slabša, kot na OP5.
Jerry000 ::
Mam sicer OPX, koncerte ne morem snemat ker hrešči ko vrag, neuporabni posnetki
SumTingWong ::
Jerry zdej se pa malo umiri prosim. Nehaj komentirati v tej temi, čisto nič ne prispevaš, hvala.
šernk ::
nikol ne bom zastopu ljudi, ki snemajo koncerte...na koncertih se uživa ne pa drži telefon v zraku pol koncerta...
Jerry000 ::
SumTingWong je izjavil:
Samo odgovarjam na vprašanja. Sorry če ne govorim laži da bi ti bilo lepše slišat.
Guzzy ::
Honestly men je Jerryjev komentar koristil, namreč tako, da zdaj vem, da ne bom več kupoval OP telefonov. (No pa sej to sem tudi prej vedel, pa vseeno)
Očitno je pač dejstvo da telefon za k snema zvok, @šernk, če boš morda zastopu če ti povem tko: jst rad posnamem kako minuto/dve koncerta, ker mi tako ostanejo lepi spomini. Včasih tudi kaj več. Niso vsi ljudje Snapchat masterji, ki dajo cel koncert na story...
- spremenil: Guzzy ()
SumTingWong ::
Kako ti je koristil? Si ugotovil kako snema OnePlus 5? Ali pa si dobil mnenje Jerryja ki ima OnePlus X?
BTW, OP5 je bil 500€, OPX je bil 250€ ob izdaji.
Guzzy ::
Maš point, sem šel gledat par videjev na YT in dejansko ni bed mic za te namene (OP5). So I take that back :)
Mam pa vpr. za OP entuziaste: zakaj se je OP odločil it v advertising, da so foni toliko dražji zdaj? Men je bil bolan koncept, ko je OP1 stal 300EUR .. zato se mi je tudi tok dopadel. Sem kupil OP2 ko se mi je enka pokvarila, pa sem očitno naletel na nesrečno letino, tako da moj naslednji zna bit kakšen Huawei
![:)](https://static.slo-tech.com/smeski/icon_smile.gif)
Karen ::
Jaz imam trenutno mislim da beta 4 Oreo-ta. Pa lahko povem, da mi Wifi tethering telefona z računalnikom poveže, samo internet preko pa ne deluje... bug. Aja, pol ko ugasneš ga pa resetira. Druga stvar je kamera... tehnično gledano kao snema, datoteka pa sumljivo kratka in seveda predvajanje ni možno. To je v prejšnji beti že delalo, pa so izgleda "pokvarili". Bom mal počakal, če pride kmalu nova verzija bete, če ne pa nandroid restore bete3 nazaj. A ostalim dela to dvoje na zadnji beti 8-ke?
broken/link ::
al pa narediš update na beta5, ki je prišla vn prejšnji teden. http://downloads.oneplus.net/devices/on...
Tezaab ::
Mam pa vpr. za OP entuziaste: zakaj se je OP odločil it v advertising, da so foni toliko dražji zdaj? Men je bil bolan koncept, ko je OP1 stal 300EUR .. zato se mi je tudi tok dopadel. Sem kupil OP2 ko se mi je enka pokvarila, pa sem očitno naletel na nesrečno letino, tako da moj naslednji zna bit kakšen Huawei![]()
Do prihoda telefonov serije Google Pixel so imeli v bistvu kar solidno konkurenco v Googlovi seriji Nexus. Zdaj tega ni več. Pa ja, kot si sam ugotovil, marketing stane.
sisemen: "Inženirstvo je v nenehni tekmi z vesoljem. Trudi se izdelati
tehnologijo, ki je odporna na idiote, vesolje pa se trudi izdelati vedno
hujše idiote. In vesolje zmaguje."
» | Kje naj nabavim OnePlus 7 Pro? (strani: 1 2 )Oddelek: Mobilne tehnologije | 10878 (5674) | Bolt |
» | OnePlus 5T (strani: 1 2 )Oddelek: Mobilne tehnologije | 13568 (8976) | dunda |
» | Xperia XZ2, OnePlus 5T ali kaj tretjega ?Oddelek: Mobilne tehnologije | 3395 (2847) | klinker |
» | Priporočilo za telefon?Oddelek: Mobilne tehnologije | 6424 (5530) | gusto |
» | OnePlus 5T je tu (strani: 1 2 3 )Oddelek: Novice / Android | 31287 (23593) | markobj |
